rochester cfm rating - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-18-2008, 09:32 PM
I picked up this carb from a buddy of mine but can't find the cfm rating anywhere online. You guys are way smarter than me so heres what I got.
7029120 69 Rochester 2-brl 396 Passenger Auto trans with AC
Old 10-18-2008, 10:37 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
Here's an easy way. Look down the primary throats. 750s have a smaller throat. Just below the booster, the primary necks down a bit and you should see three rings that appear to be equally spaced. An 800 doesn't have that pronounced necking down and there will appear to be more space between the booster ring and the throat walls. Here are some photos that might help. The 750 is on the left:
ID:	33371   Click image for larger version
Respectable paint on 120V compressor? Slickriffs Body - Exterior 43 06-10-2010 02:01 AM
Method to determine carburator CFM? jpd37 Engine 68 10-29-2006 09:55 AM
VE, CFM from Injector Flow & RPM NXS Engine 0 07-03-2005 02:11 PM
compressor CFM AhX Body - Exterior 3 04-03-2005 02:20 PM
rochester 4gc carb cfm rating? starting over in min Engine 2 08-07-2003 07:03 PM
