Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rochester to Holley
Old 11-01-2005, 07:04 AM
chev38's Avatar
chev38 chev38 is offline
Last journal entry: On the way to get worked on in KC
Something else to check is the floats. GM used a material that would soak up gas and sink, releasing all the gas you cared to put to it. If it has black floats, replace then with an aftermarket float. They are great carbs but do have a few 'engineering/finance department' problems.
