rochester leak - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-26-2002, 02:50 PM
Post rochester leak
why does a rochester carb leak gas out of the acellerter pump stem hole help please
Old 05-27-2002, 07:47 PM
Post
Sounds like you have to much
fuel in the carb. Check your
float level. Also check the
needle & seat for leaking.
Old 05-28-2002, 01:30 AM
jalopy45's Avatar
Post
If you've recently changed to an electric fuel pump you may want to check the fuel pressure.
Rods Built By Owners(RBBO)club member
wrecking yard archeologist
« headers | 400 Chev »
