Rochester Metering Rod Adjustment Help Please - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-03-2006, 09:38 PM
Hello My Name Is Craig I Have Recently Rebuilt My Rochester I Have Seen 2 Problems Since I Have Removed The Metering Rod And Now Cannot Find Anywhere What The Correct Settings Could Be Or At Least In The General Ball Park I Know That It Can Be Set By A Shadetree Mechanic Because In Older Rebuilds It Told Me But New Kit Says Factory Set And Not To Tamper With It. And I Noticed While I Had Lid Off As I Pressed The Accelerator Down That Fuel Shot Out Of The Driver Side Bank Of Carb And Barley Shot Out Of Passenger Side Of Car I Imagine Its Clogged Is There Good Way To Fix These Two Problems Im Rackin My Brain And Gas Mileage Is Killin Me
I Have An 82 Chevy 1/2 Ton With A 350 Engine And Its A Rochester 4bbl Carb Any Advice Would Be Appreciated I Dont Have The Money To By A New Or Reman Right Now Just Tryin To Get By With What Ive Got.
Old 02-04-2006, 07:57 AM
NorthStar's Avatar
Even if you removed the metering rods the adjustment is still there.
I think its called "part throttle adjustment screw".
If you messed with that screw then I would take it back apart and look at metering rods for a shiny spot and try to get adjustment close by holding power valve down and adjust height so shiny spot is aligned with jet openning.
Theres also a tool made for adjusting PTA screw through top of carb.
To get best mileage first make sure your timing set right, then go to town playing around with metering rods, jets, and turning that screw.
This book is a requirement if you want to mess around with Rochester carbs.
Old 02-04-2006, 08:07 AM
When I Rebuilt It I Cleaned Everything So Finding A Shiney Spot Isnt Going To Work. Im Trying To Find An Actual Adjustment My Carb Is Popping Real Bad And Bogging Down Im Not Sure If Its The "a.p.t. Screw" Or Not I Looked All Over The Net Last Night And All I Could Find Was This Article About Edelbrocks Mock Up Of A Quadrajet And He Said His Setting Was 2 Full Turns Out Which I Did This Morning And Seems Real Responsive Now But Still Have The Popping And Damn Near Stalling If I Push The Throttle Down These Screws Are Adjustable If The Factory Can Set Them Why Cant I Find Anything Anywhere On What The Correct Adjustment Should Be. It Almost Feels As Though Im Not Getting Enough Fuel But Everytime I Take The Plate Off The Bowl Is Full I Have Rebuilt These In The Past And They Turned Out Great But This One Is Just A Pain.
Old 02-04-2006, 12:30 PM
iS tHERE a pROGRAM tHAT cAPITALIZES tHE fIRST lETTER oF eACH wORD, oR dO yOU hAVE tO dO bY hAND?
Old 02-04-2006, 03:34 PM
Im not sure how that happened but i did notice it after i posted it
Old 02-05-2006, 10:57 PM
Go here: http://wiki.corvettefaq.com/index.php?title=Intake
Click on Lars Quadrajet Tuning Paper and download the document
Scroll almost all the way down, and there's some info on adjusting the adjustable power piston. Look for bold print that says Technical Procedure #2.
327 in 88 Truck pete379 Engine 101 01-19-2006 09:03 PM
Hot Rod of the Week suggestions? Jon Hotrodders' Lounge 30 06-02-2003 04:53 AM
200 photos from Temecula Rod Run 2003 xl1ken Hotrodders' Lounge 5 02-20-2003 06:15 PM
Temecula Rod Run photos (200) xl1ken Hotrodders' Lounge 0 02-17-2003 02:44 PM
idle adjustment 4b rochester 72 chevy elcamino Engine 4 10-15-2002 07:37 AM
