rochester quadrajet - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-31-2012, 07:06 PM
rochester quadrajet
I have a 1975 gm quadrajet that Im trying to run on my 1972 c30 chevy pickup. I believe the carburetor has a egr port.
My question is: Which ports on this carburetor do I have to plug to run on my non egr/emission 350 v-8, manual tranny pickup.
Old 12-31-2012, 07:46 PM
vinniekq2's Avatar
Plug all the ports you do not use
Old 01-01-2013, 01:37 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
In most cases the vacuum ports you'll need are a large front baseplate port for the PCV, the rear baseplate port (or a port in the intake manifold) for the PB booster, and manifold (aka "full-time") vacuum port(s) for the vacuum advance and the automatic transmission modulator. Any other ports get plugged.
Recurving a stock GM distributor will always help performance.
Old 01-01-2013, 09:05 AM
for the vac. advance on dist. you want to use a ported vac. one that applies vac. when you step on the throttle or else you will be running full advance at all times
rochester quadrajet BusterM Engine 4 08-30-2011 09:56 AM
Rochester Quadrajet! help greythorn3 Engine 4 08-18-2006 01:45 AM
rochester quadrajet low77ride Engine 12 11-04-2003 09:27 AM
Rochester quadrajet redlineps Engine 1 01-17-2003 11:00 PM
Rochester Quadrajet 57Chevyman Engine 4 11-25-2002 12:14 AM
