Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rochester Quadrajet 4MV Carburetor: Removal, Disassembly, Rebuild (Rookie Level)
  #23 (permalink)
Old 02-07-2011, 05:39 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
An OFTEN overlooked passage that needs to be cleaned, and is often plugged or obstructed, is the small, ~0.028" orifice that connects the secondary discharge port well to the main fuel reservoir.
Because it's on a 'ledge', it's prone to have deposits clog it, and it is hard to see if you're not specifically looking for it.
Be careful to not enlarge this orifice, it is also part of the secondary air/fuel ratio calibration and if made too large, will cause the secondary to go pig rich under extended WOT operation.
