Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rochester Quadrajet 4MV Carburetor: Removal, Disassembly, Rebuild (Rookie Level)
  #59 (permalink)
Old 03-18-2011, 11:52 PM
lt1silverhawk's Avatar
lt1silverhawk lt1silverhawk is offline
"But how do it know?"
Last wiki edit: How to rebuild a Rochester Quadrajet 4MV carbureto... Last photo:
Wiki Edits: 132
- Power Piston Retainer and Rod Retainer Clip Installation -
I finally tackled the power piston retainer and rod retainer clip today, which arrived last week. The rod retainer was fairly easy but the piston retainer was not a perfect fit right out of the bag. First, I had to break the old retainer. After I slipped on the new "split" type, I found that it was just a bit too large. After failing to cut off a piece of it with a knife, I ended up sanding down one side of the opening until it was perfect fit. Might even be a bit too snug.
