Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rochester Quadrajet 4MV Carburetor: Removal, Disassembly, Rebuild (Rookie Level)
  #89 (permalink)
Old 03-27-2011, 11:02 PM
V8&4spd V8&4spd is offline
Last journal entry: Paint
Do you have a thick base gasket? If not, use a thick base gasket and make sure the carb it tightened down good. Plug all the vacuum ports on the carb until after you get it running, that way you will know if there are any problems before you put them back on.
