rochester throttle shaft
before you spend money on a q-jet, check the throttle shafts for wear. usually worn out. lots have been dissassembled and re-bushed with success. just get the right guy to do that for you so the shaft actually stays centred where it was originally. otherwise idle set up can suck.
