Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rochester Quadrajet 4MV Carburetor: Removal, Disassembly, Rebuild (Rookie Level)
  #127 (permalink)
Old 04-20-2011, 09:19 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by kikkegek
Hi, I want to change my setup to the better setup, but I am looking for people and pictures that already did this on a Quadrajet.
HEre's some pics of mine.
No photos showed in your post.
While the "Best" set up shown above may well be the best, the "Better" image shows a set up that is (IMO) 90% as good as the Best set up. It's easier to do, and only requires that the return springs be attached forward of the throttle cable/linkage attachment point.
Always use a dual return spring- a "spring inside a spring" as used by many OEM's is an excellent type of return spring to use.
Below is a simple $9.00 spring and bracket sold by Mr. Gasket (P/N 720-19) that might work in your situation, and shows the type of spring to use:
