Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rochester Quadrajet 4MV Carburetor: Removal, Disassembly, Rebuild (Rookie Level)
  #132 (permalink)
Old 04-21-2011, 04:02 AM
kikkegek kikkegek is offline
Originally Posted by kikkegek
I made a custom bracket myself tonight and mounted it to the brakcet of my A/C pump. The springs are still not puling hard enough for my setup. I will have to fine tune it. I'll takes some pics tomorrow.
To add to the information. It seems that only when the engine is warmed up, I have the high idle problem, because the throttle linkage last bit has extra resistance. So the last 1-2 mm before it hits the idle screw feels heavy. So heavy when warm, that the springs dont pull it back to full idle, making it idle at about 1000-1100 rpm.
