LinkBack | Thread Tools |
Here's a pic of my 76 door jamb.
Looks like you had a large plate like mine before unless all the cabs came with pre punched holes and they used different VIN plates for special applications. |
Thank you guys for trying so hard.
To keep this thread from getting any longer and deviating from its original topic of rebuilding a carburetor, I have created a new thread. This will hopefully attract other forum members with more knowledge in this issue who may not come to this thread because its title doesn't mention factory smog equipment. For anyone else reading this, the carb rebuild was completed by page 7.
Hey dsraven,
The thread is still open to tips, pointers, cautions, warnings, procedures, etc.
HEre's some pics of mine. |
While the "Best" set up shown above may well be the best, the "Better" image shows a set up that is (IMO) 90% as good as the Best set up. It's easier to do, and only requires that the return springs be attached forward of the throttle cable/linkage attachment point. Always use a dual return spring- a "spring inside a spring" as used by many OEM's is an excellent type of return spring to use. Below is a simple $9.00 spring and bracket sold by Mr. Gasket (P/N 720-19) that might work in your situation, and shows the type of spring to use:
I would suggest you mount a bracket forward of the shaft as shown above and use the dual spring. You will need to improvise how the bracket is made and mounted, to have the spring in line w/the throttle cable (not at an angle, like if the spring were mounted to a small bracket attached to an intake mounting bolt) so the pull of the spring is in the same plane as the pull of the throttle cable. |
Glad you asked about this kikkegek. I've wondering about how to set this up myself.
Does the bracket mount in a specific place or does a hole have to be drilled in a specific place to install it? Or if that's too much work, would the setup pictured below be a better choice? It is a manifold-mount universal set up (attached are the installation instructions in pdf). I couldn't find one that was Q-Jet specific on Summit.
I made a custom bracket myself tonight and mounted it to the brakcet of my A/C pump. The springs are still not puling hard enough for my setup. I will have to fine tune it. I'll takes some pics tomorrow.
heavy throttle
check the throttle shaft bushings for wear. that is common problem. the throttle shafts bind because the butterfly valves never end up in the same place twice. thery also leak vacuum so it is hard to adjust the idle mixture. also check all the rest of the linkages and pull offs on the carb. some are affected by the choke so if the choke is still on a little that part of the linkage isn't operative. like the 4bbl lockout won't owrk if the choke is active. grab some carb cleaner/lubricant spray at the parts store and do a little clean up of all the rods etc. if you have a little extra cashola, get a new aftermarket carb and some new distributor weights and springs (recurve the distributor) at the same time. that will perk it up. have to spend a couple hundred though.
good luck, dsraven |
OK,
heres some pics of my forward "better" spring setup. Its hard to take pics, but here they are. I noticed that in my setup my spring was about half an inch shorter stretched in "idle" position then in the carbs original setup. So today I drilled two more holes too stretch it a little more. I'll take a drive tonight and report back on it. |
Hey kikkegek,
That looks pretty good. Where did you mount the bracket to? |
| Tags |
| 4mv, carburetor, quadrajet, rebuild, rochester |
| Rochester Quadrajet! help | greythorn3 | Engine | 4 | 08-18-2006 01:45 AM |
| Rochester QuadraJet 4Mv | gbowne1 | Engine | 10 | 07-28-2006 05:19 PM |
| rochester quadrajet | low77ride | Engine | 12 | 11-04-2003 09:27 AM |
| Rochester quadrajet | redlineps | Engine | 1 | 01-17-2003 11:00 PM |
| Rochester Quadrajet | 57Chevyman | Engine | 4 | 11-25-2002 12:14 AM |
