Rochester Quadrajet Carb ID? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-16-2003, 08:59 PM
Post Rochester Quadrajet Carb ID?
I just bought a 350 4 bolt 350. Block #14016379. Mortec.com says its a 77-79 350 2 or 4 bolt mains. It has a Quadrajet on it. However, I cannot ID it, even with the help from their website. This is the serial # on the carb secondary.
7043 08 QC
0383
According to their website, the 70 means its a Rochester. The 4 is for 70-76 I believe. The 3 is for the year (73). The 0 is a 49 state mono-jet. The 8 is for a Non-GM. Do you now see my delema. The QC is for the assembly plant. Where is QC. Can anyone help me please. Or give me a good website. The serial # is supposed to be 7 digits long. Mine is only 6. Need help, Bill
Old 03-17-2003, 08:22 AM
Post
bildo95....go to this addy
[URL=http://www.projectbasketcase.com/casting/carb.html]
the # on the carb should be 7 digits starting with 7026*** to7056*** this is for '66 to''76ish '76 and up 8 digits starting with1705**** and so on. This is from info that I have, hope it helps
later 4Gear
[ March 18, 2003: Message edited by: 4Gear ]</p>
Old 03-18-2003, 07:23 PM
Jared's Avatar
Post
http://www.442.com/oldsfaq/ofmpi.htm#MP%20Carburetors
Good sites for you, # should be verticly written on driver side secondary but on the outer body of the carb there will be a flat pad there. they might not tell you exactly the type but can get year and devision.
Old 03-18-2003, 07:28 PM
Post
Thanks for your help guys. I just went out to the garage and double checked. There was a 2 hidden in the dirt that I didn't catch the first time. Serial # is 7043208. Thanks again for all of your help. Bill
