Rochester Quadrajet trouble - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-23-2013, 12:40 PM
I marked the wires before i pulled them, so they are on in the right sequence. The cap can only be locked in place when it is on correctly, so that shouldn't be a problem. The power cord is on the correct spade, and there is power.
The module, cap, rotor and coil are all brand new.
still only weak/no spark :/
  #17 (permalink)
Old 05-23-2013, 02:40 PM
Edit: double post
  #18 (permalink)
Old 05-23-2013, 04:07 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by Davex View Post
For some reason my phone wont connect to the computer, so i can't upload the images i took. but it looks pretty much exactly like the image Cobalt327 uploaded.
I got a new module and capacitor (maybe at least my stereo won't sound so bad ^^)
The problem remains though. Weak/no spark (the timing light doesn't flash at all, but i have another light that you put between the wire and spark plug and that one flashes faintly), the engine gets fuel (won't start with start gas (is that what it's called in the us?) either) and the distributor has power.
You replaced the module, that leaves a couple more areas you need to check.
One is the pick up coil. It has two small wires that connect to the module and these wires are flexed many times every time the engine runs. The pick up coil itself can also fail, as can the terminals. Info on checking the pick up coil w/an ohm meter is in the link below.
Another thing to check is the ignition coil on top of the cap. Info on checking it is also in link.
Testing HEI distributor components
There's a small carbon electrode that transmits power from the ignition coil to the rotor (called a rotor bushing in drawing below). Check its condition- it can be partially seen from under the distributor cap where the tip is exposed, the rest can be seen by removing the coil.
Finally, check that there's a ground from the coil to the center position of the coil. This gound may be a wire or a solid strap, as shown below:
  #19 (permalink)
Old 05-27-2013, 02:50 AM
Turns out one of the wires to the pickup coil lost connection when it was bent
well, at least i'v got a ignition system in very good contition now
Thanks everyone for you'r help
camaro, carburetor, quadrajet
rochester quadrajet joeysworld Engine 3 01-01-2013 10:05 AM
Rochester Quadrajet! help greythorn3 Engine 4 08-18-2006 02:45 AM
rochester quadrajet low77ride Engine 12 11-04-2003 10:27 AM
Rochester quadrajet redlineps Engine 1 01-18-2003 12:00 AM
Rochester Quadrajet 57Chevyman Engine 4 11-25-2002 01:14 AM
