Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rochester from rockauto.com?
Old 05-01-2007, 10:16 PM
jimfulco jimfulco is offline
Sounds bad. If you decide to get another carb, try to find one from the same year, or at least close, I'd guess maybe '68-'72, with a 455. That should get you close, but if it still doesn't run quite right, you might be able to transfer the old metering components into the new one.
Be sure the new carb's choke setup (integral or divorced, heat or electric) is similar to your old one.
