Rock chips in new paint - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-16-2013, 02:36 PM
I have a question, I've repainted my car, it's a first paint job for me and after driving it just a couple times I've noticed some rusting rock chips around the wheel wells. It's a single stage paint from oreilly auto parts, they tell me it's duplicolor paint, but it's their house brand. I was wondering if this is normal for single stage paint and if I should possibly go with base coat clear coat next time or if it was most likely a problem in preparation? Any ideas? Thanks in advance.
Old 03-16-2013, 03:08 PM
What you have is lacquer paint, it is the most least durable paint there is. Also, the prep could make all the difference in the world. If you used their primer as well, it's lacquer too I believe so this isn't the best stuff to work with.
Old 03-16-2013, 07:36 PM
That's what I thought I remember hearing somewhere. So my nex question then is, if i paint my daily driver, would their base coat clear cow paint be more durable? And how would I be able to tell how durable the paint is before hand?
Old 03-17-2013, 09:29 AM
deadbodyman's Avatar
Wiki Edits: 11
It'll be a lot of work but you'll have to strip it to the metal...Your problem isnt so much with the cheap paint but with the primer since the chips go all the way down to the metal...
If you want it nice and want it to last I would strip it and use an epoxy primer over the metal....take the time to order some insted of this parts store crap...epoxy primers arent all the same either SPI epoxy is the most chip resistant ,user friendly epoxy I've ever used and I've been using it exclusivly for well over five years...however using it over your old paint and primer wont help, the car has to be stripped to the bare metal....
The Following User Says Thank You to deadbodyman For This Useful Post:
69 widetrack (03-17-2013)
Old 03-17-2013, 11:45 AM
Faith - Respect - Trust
Good call Mike....if you've got rust in the rock chipped area the chips are not only taking off the paint you recently applied, it's taking off the paint underneath and going to the bare metal. The only remedy as Mike mentioned is to strip the car. I would also recommend SPI Epoxy as a substrate before applying any color coat. SPI is user friendly, cost effective and affords great rust protection.
The old adage, "you get what you pay for", does apply here as well, buying your paint from the unprofessional at the same place you buy your spark plugs is like getting tune up advice from your grocer. Spend the time to find a paint jobber that can guide you in the right direction. It may cost a little more but, how much money did you save by buying the paint that's chipping off your car now.
Ray
Old 03-22-2013, 06:48 AM
Wiki Edits: 11
I was talking to a friend that used the Sumit kit and has the same problem but he striped the car and used the sumit epoxy so just because you use epoxy dosent mean you get good epoxy ,Go with the SPI.
Old 03-22-2013, 11:19 AM
X2 on that Mike...as some of you may know I recently tried SPI for the first time and abused it to no end on my test panels. It's been several months now and on one of the overly abused panels I took a ball peen hammer to the epoxy side and the un- primed side....I beat the crap out of the panel, I couldn't get the primer to let go until I used the flat side of the hammer and hit the primer the flat side of the hammer at an angle. What let go didn't go down to bare metal...so, as Mike said, just because it's epoxy doesn't mean that it's going to give you the protection that the manufacturer claims, chose an Epoxy with a proven record and if SPI can withstand the abuse it took during application and stood up to more abuse than any rocks on the road could give it, guess what I'm using
Ray.
Old 03-22-2013, 11:46 AM
Ok Ray, you sold me, I am thinking I will probably get SPI epoxy for me truck. So I go to the web site and can't find a friggin thing! The "Products" button gives me a whole list of tech info and pricing and everything under the sun BUT an actual list of products! So far, not very user friendly.
Old 03-22-2013, 12:56 PM
Brian...I won't argue with you that the web site is somewhat difficult to navigate...I just tried to go on the site and find the phone number for their jobber in the San Fran area...I think I've seen one before but, today, I couldn't find it. Send Barry A PM, he's great, and always gets back to you in a decent amount time.
You won't regret using this product Brian, it sprays beautifully, and with the way I abused it (I wouldn't abuse paint on any vehicle the way I abused it on the test panels) on test panels and after several months, what should have shown signs of rust, showed nothing, what should have fallen off by giving it a a dirty look hung on like s#@t on a blanket, an epoxy that sands better than many high end 2K primers, what shouldn't have covered real coarse grinding marks covered, and blocked out...and to this day hasn't sunk, after I prepped and painted the panel. It's only been 2 months but, I should have seen something, anything by now. I know I would have with the products I've used in the past.
I'm not the easiest guy to convert, my feeling always has been if it's working, don't change it. However, I also try and keep an open mind...sometimes what is working can be improved upon and you never know if you don't try it. I'm glad I did.
Ray
Old 03-22-2013, 02:31 PM
put up or shut up
I have a question about the SPI epoxy...does it shrink and bunch up after the car is sprayed. I was taught to be kind of light on the epoxy due to that but would love to get an epoxy I can use a sealer that won't bunch up and shrink too much. No need for any answers about flash time and application. I already know. Just would like opinions on epoxies that shrink less than others. Any opinions on this?
Old 03-22-2013, 02:33 PM
put up or shut up
sounds like it was either painted with flash rust under or it could just be the paint. I'm imagining that paint isn't a great barrier to keep moisture out. It's like trying to fill a paper bag full of water. Clear coats are inherently more solid and provide a much better barrier between your metal and the atmosphere.
Old 03-22-2013, 02:46 PM
Hey Brian...I got the information for you, you do have a local SPI distributor and sent you a PM with the co-ordinates...I'm sure it's going to do what you need and more.
Ray
repairing rock chips freethinker52 Body - Exterior 3 05-12-2011 09:03 AM
What steps to take to prevent Rock chips... jeetkunedoground Body - Exterior 32 06-24-2010 01:20 PM
Any way to stop rock chips? 14decoys Body - Exterior 7 04-11-2008 11:30 AM
Rock chips AzPAINTman Body - Exterior 2 04-04-2006 05:00 PM
Why Rock Chips? F-1Rodder Body - Exterior 16 10-08-2003 10:59 PM
