rocker arm ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-23-2006, 10:48 AM
cardaddyo's Avatar
always the hard way...
rocker arm ?
my vortec heads need a set of rockers ,and i had a question.they have been machined to accept 3/8 studs and im using guideplates.i shouldnt need the self-aligning,but do i use narrow or wide body rockers? thanks
Old 01-23-2006, 10:54 AM
engineczar's Avatar
Better off narrow, some of the wider body rockers won't clear the tubes on the center bolt valve covers.
Old 01-23-2006, 10:56 AM
cardaddyo's Avatar
thank you
Old 01-23-2006, 07:16 PM
Vortech 4.3's Avatar
jack of all trades
as i understand it. widebodies(normal) rockers will work on vortec heads. but you have to cut the pillars out of the inside of the covers, but this also makes the covers weak/er. but if you have cast covers, that may work.
Valve Lash adjustment hiball Engine 36 05-11-2009 10:12 AM
Rocker Arm question Malibu73 Engine 19 08-26-2005 11:06 AM
SBC Rocker arm Broke in 2 causes? mr_chickenhead Engine 14 04-22-2005 06:41 PM
Using old rocker arm balls as thick washers for positive stop studs? Dubz Engine 10 01-02-2005 02:04 PM
rocker arm help please windmaster Hotrodders' Lounge 2 08-05-2002 10:04 AM
