screw in studs.sounds like your spring pressure is to high for them little press in studs.what rpm yopu runnin it to ?
wow, that shouldnt happen.fresh build,hummm. somethin aint matchin up. you need to check your parts.rods,springs,shims comes to mind.
A agree with AP on the screw in studs, much easier and MUCH better than pinning. I also agree with Geezer, something in the parts or geometry of all parts combined is mismatched. Better to have a pro look at it specially after the off center drilling.
Off set pin will not cause failure. As a matter of fact. I always off set when I install them. LESS chance of failure.
You have a major geometry problem.. Have the setup checked for correct pushrod length, Coil bind/valve seal/retainer bottoming out. Rockers binding on stud etc. |
A Crankshaft Coalition wiki page that may have something of use to you is here. |
| Rocker Arm Adjusting Nuts Problems - Help Me Diagnose | leejoy | Engine | 8 | 11-26-2008 06:14 AM |
| rocker arm | jimmy dee | Engine | 2 | 01-12-2004 09:55 PM |
| rocker arm ? | boomerac11 | Engine | 6 | 06-24-2003 01:15 AM |
| rocker arm help | impala dreaming | Engine | 2 | 02-17-2003 08:53 PM |
| rocker arm help please | windmaster | Hotrodders' Lounge | 2 | 08-05-2002 10:04 AM |
