Rocker arm canting to side - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-30-2010, 10:03 PM
I have a Chevy 350 that I discovered the #5 intake rocker had canted off of the spring and was just sitting there. I removed it and discovered that the rocker had nicked into the side of the stud. I pulled the stud, tapped the hole, installed a new stud and reinstalled the rocker.
I set to TDC #1, then manually turned the engine over through each cyl until #5 was done and then set the lash. I cranked the engine and that rocker immediately pops off. I reset it again, turned on and it popped off. I did this about 4 more times and no matter how I adjust it, it just pops off to the side. What the heck is doing this?
Old 09-30-2010, 10:12 PM
ericnova72's Avatar
More for Less Racer
Did you check the pushrod to see if it is bent??
Old 09-30-2010, 10:33 PM
I did the first time i saw it off but not after. I will check it again tomorrow.
Old 09-30-2010, 10:42 PM
ericnova72's Avatar
More for Less Racer
How are the rockers guided?? Self guiding?? Pushrod guided by pushrod slot in the head or guideplate??
The rocker may be worn inn the ball area enough to ruin it. Also check the rocker closely for cracks in the ball pivot area and pushrod cup area.
Something is wrong, it doesn't just happen for no reason.
Old 09-30-2010, 10:48 PM
techinspector1's Avatar
Wiki Edits: 326
Mechanical interference somewhere.
1. piston to valve
2. spring coil bind
3. retainer to guide
4. rocker slot to stud
Is the pushrod centered in the lifter or is it sitting up on the ledge of the lifter, out of the cup? Peer down there with a strong light.
Old 09-30-2010, 11:11 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Be sure you don't have a self aligning rocker on a head made for non self aligning rocker arms. Those heads have close tolerance pushrod slots and using self aligning rockers on them can put the pushrod in a bind and cause a misalignment like you describe.
Old 10-01-2010, 06:32 AM
The lots for the rod on the head are not big. Is there a part number I can find to tell and where do I look?
Old 10-01-2010, 07:23 AM
The rockers like stock type rockers but with a roller.
Old 10-01-2010, 07:25 AM
ericnova72's Avatar
More for Less Racer
What is the head casting #?? Under the valve cover, between the 1st pair and second pair of valvesprings, or between the 3rd pair and 4th pair.
Where the pushrod comes through the head, is it a round hole 1/8" or so bigger than the pushrod, or a slot that is only as wide as the pushrod diameter??
Do the rockers arms have self aligning "ribs" on each side of the valvestem tip??
Old 10-01-2010, 09:25 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
A photo of the p-rod slot area of the head would help, too- there's no telling if the slots were opened up for using larger diameter p-rods or for use w/SA rockers. Or if the heads are for use w/SA rockers in the first place.
Old 10-01-2010, 03:33 PM
Here are the pics, not the best but as good as I could do for now. There is not much room on the sides. The holes are round on top and straight on the sides.
The casting number the best I could tell are B2441 14014416.
ID:	48568   Click image for larger version
ID:	48569   Click image for larger version
Old 10-01-2010, 04:18 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Have you changed the valve springs to something other then stock ?
Cole
Old 10-01-2010, 04:26 PM
I haven't but the head were redone before I got the car and had new springs installed.
Old 10-01-2010, 04:30 PM
eloc431962's Avatar
Wiki Edits: 37
Looks to me like you will need a set of studs and guide plates to fix the problem. JMO
Maybe someone else will chime in here in a bit.
Do you know what cam is in the engine? The specs would be nice if you can.
Cole
Old 10-01-2010, 04:37 PM
In the pictures the angle does'nt look right. Make sure that the pushrod is sitting in the center of the lifter as previously stated by techinspector1. Sometimes the pushrod will feel like it is sitting in the center but it is actually sitting up on the edge of the lifter. When you put the push rod in the hole and adjust the valve you should still be able to spin it or roll it between your finger and thumb. If you can't then it is not sitting in the center of the lifter.
rocker arm to valve stem jeepers creepers Engine 9 02-01-2009 07:21 PM
rocker arm studs twisted91 Engine 9 12-21-2007 11:14 PM
Loose rocker arm 85CHEVY Engine 6 04-09-2006 09:02 AM
Using old rocker arm balls as thick washers for positive stop studs? Dubz Engine 10 01-02-2005 03:04 PM
Rocker arm wearing into stud and bending pushrods? Meangreen Engine 19 12-28-2003 10:59 AM
