Rocker Arm Lock Nuts - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-07-2012, 05:18 PM
What is the minimum safe length of thread engagement? Longer pushrods and valves cause the lock nuts to have less thread engagement than before.
Thank you.
Old 07-07-2012, 05:28 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
What are we working on?
what size studs?
Lock nuts...like SBC self locking?
Longer pushrods and valves leave the rocker pivot ball higher up on the rocker stud. It weakens the vlve train at that point. How high are we talking?
Post a photo.
If the threads go completely through the lock nut your OK. But if it is to high on the stud, deflection at high RPM s could be a problem.
Post some pics.
Fact is stranger than Fiction
Old 07-07-2012, 06:16 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Rule of thumb for minimum thread engagement is the diameter of a stud or bolt. If you have 3/8" studs, the minimum thread engagement is 3/8", 7/16" studs is 7/16" engagement and so on. In your case though, you need a minimum of 1/8" thread above the top of the nut to allow the locking part of the nut to be into the threads of the studs. The stock nuts are a "stover" lock nut which is nothing more than a slightly deformed nut and threads towards the top of the nut. This deformed area needs to be engaged on the threads of the studs to be effective.
Old 07-07-2012, 06:31 PM
Sorry wasn't clear.
These are the rocker nuts I'm using:
COMP Cams/3/8 in. High Energy polylock rocker arm adjusting nut (4604-1) | | AutoZone.com
Old 07-07-2012, 07:04 PM
S10 Racer's Avatar
No problem 1965tripleblack. In that case, 3/8" thread engagement would be the minimum, of course more would be better. Hope that helps.
SBC Poly Lock Rocker Arm Nuts hoops Engine 9 06-13-2012 09:43 AM
torque specs for locking nuts on rocker arms RCGeyer Engine 7 08-22-2011 12:19 AM
Rocker Arm Adjusting Nuts Problems - Help Me Diagnose leejoy Engine 8 11-26-2008 06:14 AM
using a jamb nut for rocker adjustment nuts Dubz Engine 4 07-19-2004 03:31 PM
Replacing A-arm nuts and bolts 406chevelle Suspension - Brakes - Steering 1 05-07-2004 04:21 AM
