rocker arm question - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-20-2009, 03:53 PM
rocker arm question
I am wanting to get som full roller rockers for my SBC 400 build, But I'm not sure what kind I need. I know with STD stock rockers they must be self aligning(vortec heads), does this apply with the rollers too??
how are the summit brand full rollers, crane gold, erson??
Old 01-20-2009, 03:55 PM
Maybe this will help.
summit roller rockers
Old 01-20-2009, 04:07 PM
malc's Avatar
Living At The Speed Of Life
My Harland Sharps, 1.6:1, had them a long time.
Get real close.
Old 01-20-2009, 04:24 PM
malc's Avatar
If your setup reqiures self aligning rockers stock it will also apply to the rollers as well.
Check out the pushrod hole in the above pic I posted, see how tight it is,
the pushrod is held in place ?
That aligns the rocker, self aligners will have a "grooved" tip.
Like these.
Proform example.
BTW you canīt use self aligners and pushrod guideplates or heads like mine which guide the pushrod.
Old 01-20-2009, 06:52 PM
I just bought the summit aluminum 1.6 full rollers non anodized. After asking the same question you did and many responses from the members I can say I'm completely satisfied with the summit brand. They are much beefier than the ones I had(overseas rollers) they were relieved to clear 1.55 springs and all around were better built than the old ones. They also came with adjusting nuts. The Harland sharps pictured above look way thinner than the summits. I'm not saying they are better than the Sharps but alot more material. The cool thing about my purchase was Summit sent a 50.00 off coupon if I spent 200 so by the time I got the other items plus the rockers it only cost me 100, instead of 150 for 1.6 full aluminum rollers. Good Luck
Old 01-20-2009, 07:02 PM
Thanks for the follow up. Post it in that thread so everyone who references it in the future knows what the result was. Did you find out for sure who makes them?
Old 01-20-2009, 07:23 PM
A tech at summit finally was very helpful and said they were from crane and he had even used the rocker arms on his personal projects which were roller cams with 600 plus lift. Again I would love the comp pro magnums but the summit brand I bought I'll take any day of the week.
Old 01-20-2009, 07:30 PM
For $100 you had no choice.
Rocker Arm Gall uskdab01 Engine 1 01-23-2008 08:37 PM
rocker arm studs twisted91 Engine 9 12-21-2007 11:14 PM
Ford SB Rocker arm mounting question Dubz Engine 1 03-18-2005 07:12 PM
Rocker Arm Wear Question Jag Daddy Engine 2 05-18-2004 04:23 PM
Lifter Cam Rocker Arm Question edog1 Engine 11 07-30-2003 09:41 AM
