rocker arm ration conversion formula? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-10-2007, 07:59 PM
junior stocker's Avatar
There was a formula posted fairly recently for converting the valve lift when changing from 1.5 to 1.6 ratio rocker arms on a SBC. I think it was BLAZIN 72 that posted it. Anyone know it? Thanks.
Old 05-10-2007, 08:02 PM
DeathRattle's Avatar
Some Punk Kid
http://www.wallaceracing.com/rockercalc.php
Old 05-10-2007, 08:08 PM
it's really simple. devide 1.6 by 1.5 and get 1.0666. Multiply the lift at 1.5 by 1.0666 and get the lift at 1.6. .5 lift at 1.5 rocker arm ratio will be ,566 at 1.6 rocker arm ratio.
Old 05-10-2007, 08:26 PM
Oops I made a mistake. set it up as a proportion. Old ratio over new ratio = old lift over new lift. Then cross multiply, New lift equals new ratio times old lift devided by old ratio. Or 1.6 times .500 divided by 1.5 equals new lift. .533.
Old 05-17-2007, 12:01 PM
Multiply original lift x 1.067
Old 05-17-2007, 07:14 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Or you could divide your valve lift by your current rocker ratio then multiply that number by the new rocker ratio.
Like this: .480" lift(current valve lift)/1.5 (current rocker ratio)=.320 Multiply that by 1.6 (new rocker ratio) and you get your new valve lift of .512
Old 05-19-2007, 08:48 PM
383silverado's Avatar
rocker ratio formula
lobe lift X rocker ratio = lift at the valve(gross)
eg:.316 x 1.5:1 = .474
eg:.340 X 1.5:1 =.510
with a 1.6:1 rocker ratio:
eg: .316 X 1.6:1 = .5056
eg: .340 X 1.6:1 =.544
A quick way to convert the lift at 1.5 to lift at 1.6 is;
Multiply lift by 1.066666
eg .510 X 1.066666 = .544
Valve Lash adjustment hiball Engine 36 05-11-2009 10:12 AM
Rocker Arm moving around bigiron40 Engine 1 05-02-2007 05:13 AM
Rocker Arm question Malibu73 Engine 19 08-26-2005 11:06 AM
Using old rocker arm balls as thick washers for positive stop studs? Dubz Engine 10 01-02-2005 02:04 PM
rocker arm help please windmaster Hotrodders' Lounge 2 08-05-2002 10:04 AM
