rocker arm & valve tip geometry - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-16-2007, 09:22 PM
link 1:
http://www.circletrack.com/techartic.../photo_06.html
link 2:
http://www.compcams.com/information/Products/Pushrods/
link 1 shows no lift and max lift at the same point
link 2 shows no lift and max lift at opposite ends of the valve stem
what is the correct way to do it? I set it up the way comp cams said to do it, but this article in link 1 has me worried. this is for a mostly street 383 sbc.
Jerome
Old 06-16-2007, 10:00 PM
Jmark's Avatar
Both have there merits and I'm sure if you asked 10 builders, it would go 50/50. As long as the rocker does not fall off the stem, either will be fine.
Mark
Old 06-16-2007, 10:21 PM
King of my Man-cave.
Here's another link:
http://www.holley.com/data/TechServi...20Geometry.pdf
tom
Bent rocker arm stud Saltracer Engine 2 05-03-2006 09:12 PM
loose rocker arm w_rios Engine 5 03-31-2006 05:11 PM
SBC Rocker arm Broke in 2 causes? mr_chickenhead Engine 14 04-22-2005 06:41 PM
Using old rocker arm balls as thick washers for positive stop studs? Dubz Engine 10 01-02-2005 02:04 PM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
