Rocker arm wear! - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-01-2006, 06:44 AM
Guy Hiltz's Avatar
Rocker arm wear!
Yesterday I took my valve covers off to check valve lash on my solid roller equipped big block,all looked OK until I noticed that one of my Comp Cams Hi Tech S/S roller rockers was wearing on the tip where the roller is.The roller itself has actually worn at least halfway through the stainless tip where the roller and axle are pressed in,but the wear is only on one side of the tip..I dont want to go to far like that,dont want a tow truck this summer!I am planning a road trip next weekend to the Atlantic Nationals in Moncton New Brunswick and wont be able to get any replacement parts that soon,but I can get the lend of a set of roller rockers although they would be a bit different ratio,1.7 and mine are 1.73.Would it be OK to change just the one rocker and drive it like that?Has anyone else had a similar problem?The valvetrain geometry looks to be OK,and these rockers only have a couple of summers use on them,no more than 15,000 miles at the very most,all the rest of the valvetrain is a matched set.Thanks
Old 07-01-2006, 09:32 AM
King of my Man-cave.
Look closley at the valve tip. If there is any uenven wear or it the valve seems looser in the guide than the others, you may have to pull the head to fix it. If the valve end and the guide check out okay, put on a new rocker.
tom
Old 07-01-2006, 10:04 AM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Like TOM said, definitely search for the cause.
You can replace just the one rocker with the other kind and you will never know the difference IF the geometry checks OK. Work a lot of oil or assembly lube into the rocker pivots before installing.
I would bring some spares with you in case you have to change some others on the side of the road.
"solid roller equipped big block" =
Remember radical cams with high pressure springs are hard on valve train components. Lots of hot rods are only good for 20,000 miles on the street before a complete replacement is needed. You might be one of those situations.
I have seen "street driven race cars" that even required new valve guides at 6,000 miles as well as complete valve train replacement. If ya gotta play, ya gotta pay.
Valve Lash adjustment hiball Engine 36 05-11-2009 10:12 AM
Rocker Arm wear voodoosurfer Engine 4 01-09-2006 08:14 PM
Rocker Arm question Malibu73 Engine 19 08-26-2005 11:06 AM
Using old rocker arm balls as thick washers for positive stop studs? Dubz Engine 10 01-02-2005 02:04 PM
Rocker Arm Wear Question Jag Daddy Engine 2 05-18-2004 03:23 PM
