Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rocker Arms
Thread: Rocker Arms
Old 04-18-2004, 01:13 PM
60convert 60convert is offline
adjusting lifters
the time you go another half turn is when the push rod has no up and down movement, you should be able to spin it in your figers nd tighten till you feel a slight drag thn a nother 1/2 turn. sounds like you are going way to tight.
Jesse
