Rocker arms - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-01-2006, 05:47 PM
DoubleVision's Avatar
Rocker arms
I just bought a 92 Chevy silverado, it has a 4.3 chevy V6, the infamous, "350 with 2 less cylinders" I was thinking on installing some self aligning 1.6 ratio rockers on it for some additional lift to help the exhaust system I have in the works for it sound a little deeper, all I wanna know is will they work without effecting the computer? I think they will, but wanted to make sure, thanks.
Old 08-02-2006, 07:51 AM
Bumpin it up
Old 08-03-2006, 04:23 PM
Siggy_Freud's Avatar
THe computer shouldn't really know the difference. It wont change the characteristics of airflow enough that the computer wont be able to compensate. While obviously the airflow into the cylinder will increase a bit, it should still be well within range of the MAF (or MAP depending on what that particular FI uses). From my experience with ECM programming and cams, the major factor in tunability is the cams LSA rating. FI seems to like a wide lobe seperation. You can get away with some pretty high lift/duration numbers and still be okay.
Bringing history and technology together.
Which rocker arms 1.5 or 1.6 ratio??SBC batman09 Engine 47 12-04-2004 05:31 PM
Valves or Rocker Arms Tapping lewisdanw Engine 2 06-04-2004 04:52 AM
help with rocker arms on a 440 ridlenracing Engine 2 03-18-2004 03:58 PM
1.6 Ratio Rocker Arms stfinney Engine 6 11-02-2002 06:55 PM
STOCK VS ROLLER ROCKER ARMS?????? GONZALEZ Hotrodders' Lounge 7 06-18-2002 11:55 AM
