Rocker arms walking after installing vortec heads? HELP!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-15-2009, 06:16 PM
I swapped a comp cam XE-268 in my 79 350 and added a set of new vortec heads from summit racing. After finding a dead lifter (cam lobes still look good) I cant seem to keep the rocker arms from moving off center? I am using a set of stock vortec rocker arms (should be self-aligning right?) and pushrods from the older motor. What am I doing wrong here?
Thanks in advance
Old 08-15-2009, 06:19 PM
T-bucket23's Avatar
Wiki Edits: 26
Sound like you have the wrong rockers.
Chet
Old 08-15-2009, 07:37 PM
ericnova72's Avatar
More for Less Racer
The self-aligning rocker has a raised rib on each side of the valve stem contact area to keep it aligned over the valve tip. If yours don't have these ribs, they are not self-aligning.
Old 08-16-2009, 06:35 AM
Look like this one?
Shane
Old 08-17-2009, 02:39 AM
techinspector1's Avatar
Wiki Edits: 326
If you have rail rockers, check for interference where the pushrods come up through the heads.
Old 08-17-2009, 06:00 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
And don't use rails w/guide plates.
Motorheads...Need help with Vortec style heads, can they just be swapped? firstgear Engine 16 01-15-2007 12:02 AM
vortec vs phase 2 heads 71vegagt Engine 3 01-29-2006 05:12 AM
doublehumps, camelhumps, or aftermarket? 1984camaroZ28 Engine 18 01-11-2003 04:09 PM
1.6 Ratio Rocker Arms stfinney Engine 6 11-02-2002 05:55 PM
Roller Rocker arms bigjoedo Engine 1 08-27-2002 05:30 PM
