Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rocker contacting top of retainer on vortec heads
Old 12-29-2012, 03:25 PM
BOBCRMAN@aol.com's Avatar
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
Super & locks are actually 8 degree. Will not work correctly on any thing but super 7 retainers.
If your rockers are the self guided rail type. Lash caps won't work. They increase the valve tip diameter to 3/8". Rocker will be too narrow between rails.
Cheapest way out is to go with a +.050 pushrod and lightly trim the rocker rails for clearance. As long as the roller remains fairly centered on the valve you will be ok.
The Following User Says Thank You to BOBCRMAN@aol.com For This Useful Post:
flyingputz (12-30-2012)
