Were you able to widen the spring pockets without taking the guide dia. down? I'd also like to widen the pockets a bit as the spring is quite tight/binding in pocket as it sits. The Comp tool takes down the guide (spring locator) as it opens the pocket if I remember correctly. I don't want to do that. Thanks for info. I bought the heads off c-list so I don't know if valves are original. I will measure the groove to tip distance in a bit. I THINK Trick Flow has valves with longer groove to tip?
