Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rocker contacting top of retainer on vortec heads
Old 12-30-2012, 02:04 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by flyingputz View Post
Mousefink,
I pulled a couple of valves, did some measuring, and found some discrepancy. The valve with actual CONTACT with the rocker rail measured .25" groove to tip. The valve WITHOUT contact, but very close measures .29". I don't know if the previous owner swapped some valves or ground the tip down. It looks as if some grinding was done. Tip of valve has machine marks on it. Do I file off rocker rails & install guide plates, or buy new/ longer valves?
Do the valves w/the 0.250" tips have the 30 degree backcut like used on the Vortec valves? If not, it will likely be cheaper- and might run a tic better- by using Vortec valves to replace the non Vortec valves.
The Following User Says Thank You to cobalt327 For This Useful Post:
flyingputz (12-31-2012)
