Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rocker contacting top of retainer on vortec heads
  #23 (permalink)
Old 01-03-2013, 12:41 PM
flyingputz flyingputz is offline
Originally Posted by flyingputz View Post
Well, I pulled, cleaned & measured all the valves off my bad set of vortecs and here's what I found. ALL intake valves are a bit shorter than the exhaust valves. 4.88" vs. 5.91". The lock groove to tip is ALSO shorter on the intake valves. .260" vs. .290". Looks like I can use all the exhaust valves but will have to purchase new Manley intake valves. I wonder what the reasoning was for the valve variation? This would make the valve FACE to lock groove identical. Hardened tip inserts, perhaps?
Oops... I meant 4.91", NOT 5.91". Thats the plan Mousefink. The Manley race master intakes. I may not have to use the +.050 locks with them being that they're .050 longer. $119 for 8 @ Summit. Thanks.
