Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rocker contacting top of retainer on vortec heads
  #48 (permalink)
Old 01-11-2013, 03:44 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I don't recall, what rockers are you using? Agree on misleading info. But there's something that is somehow different about your set up that is causing the problem; there are a lot of guys using everything from stock retainers to the same set up you have to going back to the early-style valves and retainers (less damper) that all work w/SA rockers. So my theory is there is (at this point, anyway) the rocker arm might be the fly in the peanut butter.
