The Manley stock installed height 1.94" intake valves all have .250" (standard) length tips except for one 0.290" valve (p/n 11860-8) in the Race Master series. Manley stock installed height 1.50" exhaust valves all have .250" (standard) length tips except for one 0.290" valve (p/n 10077-8) in the Budget Replacement series. |
Tomorrow I'll measure ALL the valve tips on my old, bad set of #906 castings. I KNOW all those valves are the original parts. Sometimes I think "The General" just uses whats available! Especially if it was assembled on a Friday afternoon! BTW, the (my) short-tipped valve HAS the backcut. What I DO know is that for MY particular application I need the .290" tips. The carmakers sure don't make it easy, do they? Oh, and Happy New Year!
BTW, if you use stock diameter springs you might want to use the stock Vortec retainers- they're made to have plenty of clearance for self aligning rockers. BTW II, all I have been able to find regarding replacement Vortec valves (or more correctly, valves used w/self aligning rockers like Vortec and LT1/4, etc.) is: Intake- 0.260" groove to tip length Exhaust- 0.289" groove to tip length Why exhausts are longer I cannot say, but the first time the intake valve tips are reground, that extra 0.010" is all but gone. And as I said earlier, this is not like my Vortec valves- they're standard length tips. So take it for what it's worth- all I can say is a stock 0.250" tip is plenty for use w/the stock valve train. Last edited by cobalt327; 01-01-2013 at 01:25 AM. |
It is the keepers, not the retainers, that interfere with the self aligning rocker arm rails or nubs when using valves with .250" tips.
I furnished my engine builder with the Ferrea 5000 Series SBC valves with .256" tips and later found the problem with the keeper to rocker rail interference. After discussing the problem with my machinist, he told me the Chevrolet heads that use self aligning rocker arms have valves with .260" tips (int.) and .289" tips (exh.). He recommended Manley Race Master Series SBC valves with .290" tips, intake and exhaust. Manley Race Master Series 11863-1 and 11860-1 valves with .290" tips provides .035" clearance between the10* keepers and the self aligning rocker arm rails, when using beehive valve springs. I am using 10* keepers which are wider across the tip of the valve than 7* keepers. When trial fitting the Scorpion self aligning roller rocker arms with the Ferrea SBC valves that have .256" tips, the self aligning rocker rails actually rode on the the 10* keeper and not on the valve! The beehive retainers are smaller in diameter (1.055" O.D.) and sit lower on the valve stem than standard valve spring retainers and do not present a problem with self aligning rocker arms. |
Well, I pulled, cleaned & measured all the valves off my bad set of vortecs and here's what I found. ALL intake valves are a bit shorter than the exhaust valves. 4.88" vs. 5.91". The lock groove to tip is ALSO shorter on the intake valves. .260" vs. .290". Looks like I can use all the exhaust valves but will have to purchase new Manley intake valves. I wonder what the reasoning was for the valve variation? This would make the valve FACE to lock groove identical. Hardened tip inserts, perhaps?
I used Manley Race Master Series SS valves that have .290" tips and are 4.951" long.
I used those valves with Comp Cams 26918 beehive valve springs, 10* keepers and retainers. We equalized the beehives at 1.750" with 144 lb. seat pressure and 330 lb. at .500" valve lift, according to a Rimac spring tester. |
My machinist uses a Serdi valve grinding machine and the finished intake and exhaust valve tip heights were identical using a .050" intake valve margin and .080" exhaust valve margin. When I picked up the heads at the shop, the first thing I did was to place a steel straight edge on the valve tips and all valve tips touched the straight edge. There is no reason to use +.050" locks with the Manley valves if the valve seats are ground with .050" intake and .080" exhaust valve margins using a Serdi machine. I furnished a set of +.050" locks to my engine builder in case he needed them to use with shims in order to eliminate the exhaust valve rotators and achieve 1.750" spring height. Standard Vortec spring height is 1.700" . He eliminated the rotators with .090" Alex's Parts hardened valve spring shims without using the +.050" locks. |
| The Following User Says Thank You to MouseFink For This Useful Post: | ||
flyingputz (01-03-2013) | ||
One of those damn little details to keep track of. Bogie |
| The Following User Says Thank You to oldbogie For This Useful Post: | ||
Would it not be more cost efficient to install the guide plates under your screw in studs and swap out the rockers rather than redesign your intake valvetrain? I'm assuming this would be easier than the swapping valves and locks and keepers. Are your current pushrods hardened? If so this route would cut back greatly on labor as well. Another thing comes to mind is the center bolt valve covers vs. the sbc style as he non self allinging Are narrower to allow for clearance on the vortec bolt patterin.
I used 10* Super Locks designed for lash caps on my first pair of heads with SA rockers and they provided additional clearance for the SA rocker arm rails. I put about 4,000 miles on them with no problems. I did not use the lash caps, just the locks.
I replaced those heads recently and used regular 10* locks and Manley SS valves with .290" tips. That is the proper way to do it. The .290" tips provide .035" clearance between the locks and the SA rocker arm rails. |
I wouldn't get carried away enlarging the spring pockets on production Vortec heads. This can easily weaken the pocket edge where it locates above the port as it turns into the pocket. This often becomes a failure point opening a crack as the head gets some miles on it. If you need better springs the production Vortec is way better off with beehive springs that fit into the production spring pocket. Bogie Last edited by oldbogie; 01-10-2013 at 09:44 AM. Reason: your to you're |
| 350-flat top pistons..vortec heads? | jameshemi | Engine | 6 | 06-25-2012 12:25 PM |
| broken rocker stud #8 exhaust vortec heads | psbaker75 | Engine | 9 | 03-08-2011 05:31 PM |
| vortec heads 1.5 or 1.6 rocker | Hanks56Chevy | Engine | 7 | 09-19-2010 05:28 PM |
| Rocker arms walking after installing vortec heads? HELP!! | cochino12 | Engine | 5 | 08-17-2009 06:00 PM |
| Rocker to retainer clearance | MEAN_SBC | Engine | 4 | 02-22-2005 08:47 AM |
