Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rocker Issue!! *** Happened?
Old 03-07-2013, 04:00 PM
ssmonty ssmonty is offline
Did you check to see that the pushrod was clearing the end of the guide plate slot? You probably know that the 1.65:1 ratio moves the pushrod closer to the rocker stud(bottom of guide plate slot) than a 1.5:1 ratio rocker does.
