Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rocker Issue!! *** Happened?
Old 03-07-2013, 05:05 PM
Landshark928's Avatar
Landshark928 Landshark928 is offline
FrankenPorsche
Originally Posted by ssmonty View Post
Did you check to see that the pushrod was clearing the end of the guide plate slot? You probably know that the 1.65:1 ratio moves the pushrod closer to the rocker stud(bottom of guide plate slot) than a 1.5:1 ratio rocker does.
ssmonty
I didn't check. My bad. I'm guessing the step on the push rod end was catching on the guideplate.
