Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rocker Issue!! *** Happened?
Old 03-08-2013, 06:45 AM
Richiehd's Avatar
Richiehd Richiehd is offline
JS-70
What heads are you using? When I got my World heads they came with the wrong guideplates. I bought the proper guide plates direct through World (Flat ones) I then had to adjust each one of them so the rockers were directly on the tip of the valve. I then had to grind away a couple of threads of two cylinder head studs (Head studs installed instead of bolts) where the stud had not been installed deep enough Quit frankly a 1.65 rocker is alot of lift for a small block. I would have used a bigger cam if I wanted more lift.
