Hello all I am new to this so here goes.....I am trying to put a freshly machined 318 together and just rec'd it back from the machine shop.....I am at a stage where i am putting the rockers back together and the more i read the more things tell me that I should be putting the rods and rockers back in the same spot they came from?? Well mine came back in a box..go figure. Here is the issue Some of the rockers are marked RT (i will assume right) some are marked RH (right hand??) does it matter??? Please help as the warm weather is fast approaching
i have heads with all the rockers marked rt.i don,t really think it matters.the only thing i could think of is one could be marked for exhaust and the other for intake.are they a different size ?
Thanks for the reply Buff ...everything looks the same...so I am just gonna put it together and hope things work. If you happen to think of anything else drop me a reply. Thanks again!!
There are definitely left and right offsets on the early LA small block Mopar rocker arms. I'm not sure right now on what the stampings mean what but if you hold them up and look down at them from the backside you'll notice that the valve ends are all the same but the pushrod cups are offset either left or right. When you slide them onto the rocker shafts they must go on in a certain order so that the pushrods don't hit the heads.
As Bill has stated there are left and right rockers.
Look close at the push rod cup and you will see the different locations. Then i would make sure you have 8 of each hand. Go over to the engine and you will see that you have a pattern starting with the exhaust valve then 2 intakes side by side then 2 exhaust side by side then 2 intakes then one exhaust.Slide the rockers onto the shaft so that the correct offset lines up with the correct valve location... I am not positive but i think if you get them on wrong the push rod will rub the head.... So pay attention to what you are doing..
Thanks guys...looks as though I have it figured out. Well at least if fired up and didn't make any strange noises
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
