rocker oiling problem chev 235 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-02-2012, 08:38 PM
Helping my brother work on his recently purchased 58 pick up. He wants to keep the six running, at least for a while. Oil to the rockers is almost none. I remember, as a very young lad, one of my Dad's friends installing what he called an external oiling system. It seems like I remember a small tube being installed from the side cover & up the outside to the plug in side of the head. Could this memory be correct or is it more likely the added tube came around the engine and into the hole in the head. Any info will be appreciated.
Old 02-02-2012, 08:41 PM
Low n' 51ow's Avatar
It's slow, not to low.....yet.
Last journal entry: 1951 Styleline DeLuxe
I have a 235 in my 51 and during my research I did read that alot of times the oil tube to the rockers would get plugged or clogged and an old time fix was to run a new tube direct to the top of the head and direct it onto the rockers. It has been done, but I don't know exactly how to tell you to proceed.........
engine oiling problem mitchc Engine 9 10-15-2009 09:33 AM
SB 383 Lifter Oiling Problem leprosy Engine 5 07-18-2007 06:41 PM
chev oiling system? jtybt Engine 5 04-23-2007 09:07 AM
350 Chevy Oiling problem bigballsracer Engine 6 01-30-2007 03:12 AM
Oiling problem Eric327 Engine 2 01-01-2007 09:16 PM
