Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - rocker panels ????
Old 11-15-2009, 04:53 PM
deadbodyman's Avatar
deadbodyman deadbodyman is offline
Wiki Edits: 11
I'd start with the floor,start where the floor meets the rocker and cut along that edge..cut a section of the floor thats a lot smaller than the new floor but big enough to set the new floor in and mark all the way around the edge of the of the old floor to show you where it needs to be cut then cut it two inches below the line all the way around...use drill screws to fasten the new floor down tightly and re mark it again for a closer cut with a 1/2 of lea-way all the way around weld one side then underneath then move to the rocker dont forget to punch holes in the floor where it folds down to meet the rocker you'll need them for welding the floor to the rocker.
