Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Rocker pedestal repair on cast head?
Old 05-11-2011, 07:09 PM
ForceFed86 ForceFed86 is offline
After running a new personal best first run out. I broke my rocker pedestal. Then I Found some more disturbing carnage. aft and middle rocker pedestals are cracked. Strangely the fwd rocker is the one that broke. Think this is something I should try to tig repair on the car? Or is that a bad idea because it's iron? And ideas?
This is the middle, it's not so bad.
The aft is the bad one.
This low rpm 3.8 went 10.24@133mph @ 6200 rpm with a 26" tire. Assuming I can fix the rocker pedestals. I plan on going to a 28" tire to lower the rpms.
Thanks.
