Hotrodders Bulletin Board > Tech Help> Engine
Register now (free) or login to remove ads
Thread Tools Search this Thread share on Facebook
  #1
Old 09-21-2003, 04:18 PM
KeithB123 KeithB123 is offline
Rocker ratio on SBC
I was told that SBC`s like 1.5`s on the intake and 1.6`s on the exhaust.
Any opinions?
  #2
Old 09-21-2003, 04:41 PM
jamnut's Avatar
jamnut jamnut is offline
Rebuilding AGAIN!!!!
Re: Rocker ratio on SBC
Any opinions?
I think it really depends on the application. That's one of the reasons that you can buy dual pattern cams these days, at least taht's what I was led to believe.
Old 09-21-2003, 08:24 PM
302 Z28's Avatar
302 Z28 302 Z28 is offline
I believe that the ratio is 1.5 on both intake and exhaust. Big block rockers can be used for a 1.6 ratio...I think.
Vince
Old 09-21-2003, 08:33 PM
BOBCRMAN@aol.com BOBCRMAN@aol.com is offline
Big block rockers are 1.7 and too long for a small block.
Old 09-21-2003, 08:41 PM
lluciano77's Avatar
lluciano77 lluciano77 is offline
Short changed on common sense
Running 1.5 I, and 1.6 E could better. It depends on your camshaft, valve sizes, cylinder head flow, exhaust sytem, induction, etc. The only real way is to know is to try it and see what happens.
Old 09-21-2003, 08:55 PM
V8 S-10's Avatar
V8 S-10 V8 S-10 is offline
v8s10.org
Depending on the cam sometimes we will swap between 1.5 and 1.6 rockers on our race car.Sometimes the 1.6s on the intakes sometimes just on the exhaust.
Smokey Yunick used to modify the 1.7 big block rockers to work on smallblocks.It was alto of work though because he had to move the rocker studs to a differnt location.
Old 09-21-2003, 09:08 PM
lluciano77's Avatar
I have 1.6s right now. I was thinking of trying some 1.65s on the exhaust with the 1.6s, and then trying them on the intake the other way.
Old 09-22-2003, 02:59 AM
malc's Avatar
malc malc is offline
Running on empty
Chevy,according to their Power book did some rocker testing and found the best setup is;
Cylinders 1,2,7 and 8 get 1.7:1 inlet and 1.65:1 exhaust.
Cylinders 3,4,5 and 6 get 1.65:1 inlet and 1.6:1 exhaust.
That was on a 358ci smallblock built to NASCAR specs a tad
over the top for the street, and it all depends as well on the rest of the setup.
Old 09-22-2003, 11:59 AM
engineczar's Avatar
engineczar engineczar is offline
The conventional setup if you're going to use unequal ratios is 1.6 on the intakes and 1.5 on the exhaust. It boosts the area under the curve on the intake without over-scavenging the exhaust.
BSE Racing Engines
Old 09-22-2003, 12:18 PM
Wrencher's Avatar
Wrencher Wrencher is offline
The 1.6's on the exhaust would increase the low end torque, horsepower on the intakes.
Back to top
Search this Thread:
Advanced Search
vB code is On
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
