Rocker stud sealant - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-16-2010, 07:24 PM
Rocker stud sealant
The threaded boss of the intake studs on my brodix aluminum heads go thru to the intake port. what would be an appropriate sealant to use on the rocker stud threads? thanks
Old 04-16-2010, 07:40 PM
4 Jaw Chuck's Avatar
Hundreds of choices, Permatex and 3M make some great thread sealing products used for hydraulic applications which will not leak and offer some thread locking ability. Then there are anerobic sealants that only cure once out of exposure to the air. Some people even use liquid pipe thread dope, others use non-hardening sealant.
The only thing I wouldn't use is silicone.
— Han Solo
busted rocker arm stud. phooey. Biscuit6447 Engine 9 09-21-2009 12:09 PM
Bent rocker stud V8 Super Beetle Engine 4 06-11-2008 10:26 AM
replacing pressed rocker stud with threaded stud DHMag Engine 16 09-06-2007 05:57 PM
Pulled rocker stud, and more? :( Gokussj5okazu Engine 17 03-22-2007 05:53 PM
Rocker Stud problem trenchdog73 Engine 2 02-15-2005 12:20 PM
