rocker switch wiring
hey guys,
Im am completely re-wiring my 84 cj7 and ran into a snag. I ordered a couple of marine rocker switches and im not too sure how to wire em. Its a CARLIN TECHNOLOGIES DPDT marine style illuminated rocker switch (3 position - ON /OFF/ ON) with 7 terminals on the back. On the left there are 3 terminals (with numbers 8,2 and 3 next to the terminal), and on the right side there are 4 terminals ( numbers 7,4,5 and 6). I got a SPST with just 3 terminals on the back and the 3 is load, the 2 is supply, and the 7 is ground, im just not sure if its the same on the DP and what the other terminals are.I mean i know about the DP and all of that and how its used and everything, i jus dont know what the actual terminals are. If you could clearify what numbers are my other loads, and if there is another ground or what would be greatly appreciated, thanks! Last edited by 350cruiser; 11-21-2008 at 10:40 PM. |
Sorry about that ,I didn't address your question about the terminal designations, if the DPDT switch are inline as you look at the back then8&3 go to your circuits,2 is common(power)7&5 to your circuits,4 is common(power) and 6 is ground for the bulb in the switch.Had a Senior Moment or not awake yet!(pick one!) Hope this helps.
Kenny Lost your job yet? Keep buying foreign. |
| Question about switch wiring | gwcoolman | Electrical | 8 | 01-25-2008 03:02 PM |
| 85 fuel switch wiring | thunder customs | Electrical | 3 | 03-14-2007 07:20 PM |
| Starter switch stock to modified wiring question. | Kallie49 | Electrical | 5 | 06-23-2006 06:01 PM |
| How Does This Stuff Work? | docvette | Electrical | 3 | 06-18-2006 03:00 AM |
| need wiring diagram or pic of ignition switch | 69chevelle | Electrical | 1 | 01-09-2003 03:58 PM |
