Rockers - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-25-2010, 06:05 PM
George Humphrey's Avatar
Last journal entry: '64 Buick Special
Rockers
Will Chev 1:6 stamped steel self aligning rockers for Vortec heads work on older heads with non self aligned heads?
Old 03-25-2010, 08:19 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
Yeah, they will. You just want to make sure you have pushrod clearance at the hole/slot where the pushrod comes up through the head. You can't have both systems at work or you'll experience bind. You also want to make sure you have enough valve tip coming up past the retainer so that the rocker isn't riding on the retainer.
self aligning rockers mtnrat Engine 6 10-06-2008 09:15 AM
SBC Solid Cam, Rockers Hitting Valve Covers?! ezobens Engine 11 05-01-2007 01:24 PM
Considering 1.6 rockers 302 Z28 Engine 3 07-25-2006 06:04 AM
Rockers cutting studs on 350 sbc western star Engine 12 06-24-2004 05:09 PM
Roller Rockers black66 Engine 5 10-23-2003 07:32 PM
