Rockers - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-14-2003, 09:47 AM
onehotchev's Avatar
Post Rockers
Can someone tell me What heads use self aligning rockers
Thanks
Winning isn't everything but loosing sucks
So drive it like you stole it
Old 02-14-2003, 10:08 AM
Post
for what kind of engine ford,chevy
Old 02-14-2003, 11:42 AM
onehotchev's Avatar
Post
Chevy
Old 02-14-2003, 11:43 AM
E.T. divided by $ spent= Speed
Post
The Vortec heads use um.And I think any SBC past 1992,not really sure.
I prettend the SBC stopped being made in 1985 so after that I know nothing.
Old 02-14-2003, 01:13 PM
Post
I believe it was all 1987 and later SBC's had center bolt valve covers (requiring the self-aligning rockers). Also, the intake bolt angle was changed at the same time.
Old 02-14-2003, 02:56 PM
onehotchev's Avatar
Post
Ok I don't want to sound dumb
but I have never used a set of heads that used self aligning rockers before
So what happens if you don't use them ?
Thank for your help
Old 02-14-2003, 08:49 PM
onehotchev's Avatar
Post
Thanks for all the info
[ February 19, 2003: Message edited by: onehotchev ]</p>
Old 02-19-2003, 03:22 PM
onehotchev's Avatar
Post
The heads I have
have slot for the push rods
Not a hole like the Vortec heads
So am I correct in guessing that they don't need self aligning rockers ???????
casting #14102193
and a Date of B-02-1
I am trying to figure out that date code.
I looked it up at <a href="http://www.mortec.com" target="_blank">www.mortec.com</a>
and they say 87-up so is that
February 2nd 1991
Thanks for the help
Old 02-19-2003, 03:54 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Post
You won't need the self aligning rockers nor the hardend pushrods either. The slot will take care of the job. One more note, Never run aligning rockers with a slot. It causes binding of the pushrod. A long cam sometimes will cause the binding in that area so watch out and grind there if it's needed.
Old 02-20-2003, 07:23 AM
Post
While your at it buy a set of roller tips, can't hurt, only about $125.00 a set
Old 02-20-2003, 07:06 PM
onehotchev's Avatar
Post
First off Thanks for all the help
When buying rockers
does it make any difference that
These heads are center bolt vale covers ?
Thanks again
[ February 20, 2003: Message edited by: onehotchev ]</p>
Old 02-21-2003, 01:33 PM
Post
Just tell your parts person what type heads you have and they should be able to get the right rockers. I've got vortec heads, center bolt valve covers, and use self aligning roller tip rockers. If you don't have a good parts person contact Scoggin Dickey they sell speed parts for a reasonable price.
