Rockers are hitting Retainers....?? - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 04-03-2009, 11:18 AM
Originally Posted by 71chevy
Was curious what you came up with / ended up doing to solve problem of rocker arm hitting spring? I am having same problem with RHS protorker heads and Comp cams magnum roller tip rockers 1.5 ratio, but looks to me. moving everything up (longer pushrod/longer stud) will throw off my geometry.
Die grinder across the bottom of the rocker where clearance is an issue. Then polish the clearanced area.
Bogie
  #32 (permalink)
Old 04-05-2009, 08:36 PM
nastynova's Avatar
one of those things where i got frustrated... and bagged it up... it turned cold and I havent worked on it since...
Rockers and valve covers Bluepen Engine 5 04-17-2008 08:23 PM
SBC Solid Cam, Rockers Hitting Valve Covers?! ezobens Engine 11 05-01-2007 02:24 PM
Considering 1.6 rockers 302 Z28 Engine 3 07-25-2006 07:04 AM
Proform roller rockers! *** is wrong? Sagacious Engine 21 11-23-2005 03:58 PM
