Rockers and valve covers - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-16-2008, 08:01 AM
Bluepen's Avatar
Just a firefighter
Last wiki edit: How to title a hot rod
Last journal entry: New rear rollpan installed
Wiki Edits: 2
OK I am totally messed up on this and it most likely is very simple except to me.
'78 sbc 350, stock castings, unknown if milled, small cam, stock rockers and rods, did not build this motor the PO did.
Now I got a set of cheap stamped steel valve covers and some of the rockers hit the intake side of them not the top. OK they are stamped steel and I wasn't suprised at that, a few taps with a hammer, fixed. Now I've got a set of GM Performance cast billet aluminum covers, good set. But I have the same problem, some of the rockers are hitting the intake side of the covers on both sides. I thought maybe wrong rockers or rods because I didn't build the motor. I went to the parts store and pullled new ones off the shelf and they match perfectly. The rockers are sitting in the center of the valve stems so this is where I'm lost.
Can anyone tell me what might be wrong in this picture?
Thanks
Old 04-16-2008, 11:48 PM
Thanks
Unfortunately not really sure. If it isn't an issue of where the heads center on the cylinder bore, they make and sell offset alignment pins for the purpose. It could be the the pushrods aren't the correct length causing the rocker to sit low on the pushrod side which might get it into contact with the cover. Last idea would be the studs are located incorrectly either in position between the E and I sides of the head or that they are bent toward the intake side.
I'd start with pushrod length and vertical squareness of the rocker studs as it takes observation and measuring rather than major disassembly, some disassembly but not of heavy stuff. Go to the comp cams web site, they have a good tech article on how the rocker should address the valve stem. The latter situation can be caused by one or several of these factors 1) head milling, 2) block deck milling, 3) long stem valves, 4) larger ratio rocker arms 1.5 to 1.6 for instance, 5) roller rockers that simply occupy more space, 6) short push rods, 7) incorrect lifter length or adjustment resulting in the lifter height seemingly to be too short lowering the pushrod, 8) cam lobes out to lunch lowering the lifter and pushrod which will drop the rocker too straight so it might scrape the cover.
OK, it's late and I'm out of ideas, this ought to give you some food for thought, however.
Bogie
Old 04-17-2008, 05:13 AM
Last journal entry: PICTURE TEST
valve covers
Loosen the bolts a bit, push the valve covers towards the intake side as far as they will go, hold them there and tighten the bolts. The problem will go away 99% of the time doing this. The natural pull of gravity will have the covers towards the exhaust side of the head when you put them on.
Keith
Old 04-17-2008, 06:29 AM
missed something
Old 04-17-2008, 06:43 PM
DHMag's Avatar
Mr Gasket makes 3/16" valve cover gaskets to cure that problem.
Old 04-17-2008, 07:23 PM
Some of the Chevy valve covers are made so there is a prefered top side. The difference is minimal but enough to clear the rockers. The top side is more at a 90 than the bottom. Years ago I found out the hard way.
SBC Solid Cam, Rockers Hitting Valve Covers?! ezobens Engine 11 05-01-2007 01:24 PM
Loose rockers, bad? steveyb4342 Engine 8 04-15-2007 06:40 AM
Roller rockers under stock valve covers curtis73 Engine 4 11-19-2006 06:53 PM
Re: Roller Rockers, Stud Girdle - Which Valve Covers? jerseyjeff Engine 5 11-07-2003 05:07 AM
need chevy OEM baffled type valve covers TVR383 Engine 8 10-18-2003 05:22 PM
