Rod bearing clearence? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-28-2005, 03:00 PM
They call me the Malibu
If I use the EXACT bearing to replaced the worn bearing.
Is there a clearence issue I need to know about? Or do I just pop them in and torque to specs?
Sorry if this is a dumb question.
Old 06-28-2005, 03:16 PM
DoubleVision's Avatar
In most cases you`ll likely land on your feet and be fine, however, not knowing the specs can lead to disaster as well, especially if you don`t know the history of the engine. Anytime a engine is built, the specs should be checked, you can check the bearing clearences with plastigauge, anything under .001 is not enough and anything over .003 is too much.
Old 06-28-2005, 04:05 PM
blndweasel's Avatar
paints everything flat black
Last journal entry: September 2005 - Current
question: why does the bearing need to be replaced?
wha happend?
tbw
Old 06-28-2005, 04:35 PM
messed up
Long story short. I have solid lifters, and didnt adjust them after initial startup. The nuts came loose on int and exh on cyl #3. Neither valve was opening. Limped it home, which I shouldnt have done. Retightened of course.
So I think the excessive cylinder pressure hurt the bearing.
300 miles later I get the knocking sound. Pulled the bearing. Its bad.
But no damage to crank or rods. So can I just replace it? The engine has 400 miles on it.
Old 06-28-2005, 09:38 PM
TurboS10's Avatar
Last wiki edit: Auto Terms and Definitions Used in Modern Engine T... Last photo:
Wiki Edits: 2
If the bearing is bad, then it is VERY likely that the crank is damaged. You need to take it to a machine shop and have it checked out. It will likely need the rod journal to be turned down.
Chris
Old 06-28-2005, 10:46 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
bearings
Drag your finger nail across the crank. If you can feel any imperfections you have damage. Also mic out the rod hole. It may have went oblong. It might be taller than wider now. If it is, it needs to be resized.
Old 06-29-2005, 09:10 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Doesn't sound like the nut's cam loose. Sounds like the piston hit the valve and bent a push rod or something. Loose lash and a bad bearing on the same cylinder would not be coincidental.
stroke to rod ratio jacobm99 Engine 28 12-16-2013 06:46 PM
383 vs 350 TheCiscoKid Engine 86 05-03-2008 04:10 PM
327 in 88 Truck pete379 Engine 101 01-19-2006 10:03 PM
Connecting rod side clearence ???? ktorr22 Engine 8 08-16-2004 08:20 PM
longest rods in std deck 454 bbc?? deuce_454 Engine 11 01-30-2004 11:06 AM
