rod bearing question - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-06-2009, 05:38 PM
Im helping a friend with his 327 in a street strip car, saturday he had a weak valve spring and it floated the valve, when it did the piston smacked the valve bending it. Engine is still in car we tore top end down and inspected the piston it just nicked it very little, i think were ok there, so could that have caused any damage on the rod bearing on that cylinder? If socan we pull pan and take cap off and look at it and if its fine put it back on and retorque it. Or is that a major NO NO. The motors three years old and seems still strong with great oil psi till this lil misshap. Thanks John
Old 04-06-2009, 05:49 PM
techinspector1's Avatar
Wiki Edits: 326
I'd be more worried about a crack in the piston than I would about the rod bearing.
http://www.woodwardequipment.com/spotcheck.html
Old 04-06-2009, 05:59 PM
we have cleaned it all up and inspected best we can, there forged pistons so not sure if that makes much difference, on the rod bearing cap is it safe to remove it for inspections then put it back and retorque to spec or could that cause bearing failure.
Old 04-06-2009, 07:32 PM
If it were mine I'd pull the engine and inspect it. But I'm anal about these things, I don't like known, potential failures gnawing on the back of my mind.
Maybe it's OK, maybe it isn't, I just don't like finding out it isn't with a big bang, a cloud of parts, steam, coolant, and oil.
Bogie
Old 04-06-2009, 07:41 PM
Ya that isnt any fun, sounds like a lil exsperiance talking there lol. thanks guys
A Rat Rod non Rat Rod Question? 50BLUECHEVY Suspension - Brakes - Steering 10 02-10-2009 03:28 PM
connecting rod question. nickynos468 Engine 9 12-16-2008 02:37 PM
Need rod bearing help ASAP! PLZ CustomConspiracy Engine 13 12-01-2008 02:46 AM
Question hiem joint / rod end plating western star Suspension - Brakes - Steering 7 10-05-2005 10:33 PM
not a rod question but an engine swap question for a daily driver.. DeathByGreaser Hotrodders' Lounge 2 01-22-2004 10:59 PM
