Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - rod bearing take a look
Old 07-26-2011, 05:34 AM
CNC BLOCKS NE CNC BLOCKS NE is offline
A score like that is from debris and its always a good idea to plug the oil filter bypass and use a good filter. And make sure the plug under the rear main cap installed.
If you have one of he blocks with the press in plug under the left head on the rear of the block that has to be removed to clean that galley porperly.
